  #11   Ban this user!
Old 03-17-2009, 04:33 PM
slideleft slideleft is offline
slideleft is on a distinguished road
Thanks for the help Superman.
What file format do you have best success bringing in as solid. I succeeded with .sat, but when I follow the create surfaces routine, I get surfaces, but they are apparently overlain on the solid as I get the psychadelic 2 color depiction of part.
Problem #2- this happens to me often, and sometimes I get it to go away without knowing exactly what I did- when using surface rough pocket routine, I select drive surfaces, and the outer containment boundary (inside as you suggest), but when generating operation I get error message(s)- "No cut found-check tool, cut dpths, or use tool containment boundary". Followed by "unable to determine a valid machining zone- no tool path created". Followed by "error regenerating operation! surface rough pocket"
Thanks again,
Jeff
