Thread: Need Help! Heidenhain 4th axis
Old 03-17-2009, 01:56 PM
Jukka Honkanen Jukka Honkanen is offline
Jukka Honkanen is on a distinguished road
Encoder input
on the Heidenhain TNC155 has only to possibilities.
If the rotary encoder is fitted to the center of the table the line count must be either 18000 or 36000.
Those encoders are very expensive. If you fit the encoder to the motor then you need to calculate the ratio of the motor/table and come up with the same line number / table turn.
The signal of the encoder must be 11uApp (16uApp in the older version do well)
Jukka
