Originally Posted by chaz6966 ok i will try that.
when i open cam tree the, the cam part tree is minimized and the turning stock and edm stock are expanded.
is there any way to keep the cam part expanded and keep the turning stock and edm stock minimized.
or even get rid of the lathe and edm stocks off the tree for now. i dont have a need for them. |
I dont think this is in it yet. I have seen it mentioned before though.
BTW: Mine opens up as all three collapsed. Make sure you are on the latest build of 1276.
Go to Help menu-About BobCad and see if it says Build 1276. If not then:
http://www.bobcad.com/updates
run this as an updtae to the existing install. It is not a full install. It's an update.
