I went out and checked some of the stuff you are talking about. I checked every fuse that is visible. I also found that some of the are stategically hidden behind the motor drivers. I do not know where the 24vdc supply and the logic supply are located. I checked the FMDC " whatever the heck that stands for " and the little blinky lights are blinking at a dissimilar rate at the end of the string. Will have to wait for the new year to get the manuals. I checked the voltage out of the transformers and they are 121.2 on each of the legs.
I am running out of things to check.
Here is a list of what I have checked.
I hooked up air to it, same error. "Does it have to have air"
Made sure the way oil is full.
Made sure the spindle oiler is full.
What else could it be? |
