Hey Laserpro a friend came over from Kawasaki rail car and he show me what my problem was first go fast key 134 select the lst file and press copy. Enter C:\DH\TOPSMANU.DIR\FILENAME.LST ok then alt + tab update quick tool then do what you said but when I save 9 grid 2 make with subs our software is a little different. In the dxf file I was able to cut parts right from a dxf file and mini nest them. Having a problem making a grid it grids full size sheets. Also tried graphic programming it is like my old 240 punch trumpf graphic when I get time I will play with text & sign generator & wrenches.
Do you know what is laser song? Up at trumpf in training they had the machine playing a song as it was cutting I don’t have a clue how to do this. It is a song to laser cod conversion. Also I did not know you could split .grs .grd files. Thanks for your help but I will stick to my software in my office. Its good the guys at the machine. |
