Originally Posted by Al_The_Man In the past I have used something that looks very close, it was made by Item Products, I am not sure if they are still around, I seem to remember they were taken over at least twice.
One of the extrusions was nice as it had galley's running through to pipe oxy & gas through and you just drilled and tapped a fitting where you wanted to exit for multi-torch CNC Gantry.
Al. |
Item products sounds familiar, and yes the extrusion is heavy,rigid and very versatile. At any rate I have 2 60" and 1 72" lengths and I would like to keep everything the same if I need to pruchase more as my router design develops. It's like 'Murphy' change is almost certain to happen.
Paul
