i have seen the same issue on a older Sodick Mark 11 control. What it ended up being was the battery backup was dead and it lost some of the parameters. Pull the pannel and change the D batteries. Another thing to try and and swap the cables from the U drive to the X drive and see if when you hit the X+ that the U axis moves. That is a simple way to test the drives and boards. |
