Scott,
I haven't had a chance to test the install program. Some of the files may be out of date on newer systems. The file transfer app works great on 98, ME, XP and NT. (I've tested it on these systems)
If you have a problem with the install there is a simple work around; there is a .cab file inside the .zip file that you can open with WinZip. Extract all the files to the folder of your choice and run SComm.exe. It will read everything it needs from the local folder instead of the system. (Not to worry about conflicts due to running these files locally; these controls will not interfere with anything else that may be running, except if you try to send data thru the same comm port from 2 different sources at the same time, i.e. SComm and Cimco or something.)
If you have ?'s or !'s let me know.
'Rekd teh If
VB wasn't so damn easy, I'd have tossed it out long ago..
