From what I gather, It is double rotary tables. One wraped on the y axis and one on the X axis.
Poppabear,
I have access to a CAM package that will output 5 axis G-code in the dual rotary table config. It only has a few post proccessor options but maybee I could tweek it to work with mach. So my question is if you have a CAM that will output 5 axis G-cdoe in the 3+2 configuration then mach can do 5 axis just fine?
Thanks |
