Uninstalling and reinstalling isn't necessary.
The reason that there is no data to verify is because the directory that BobCAD is saving the data to, is inacessible to Predator. You just need to tell BobCAD where to put the files.
Click on Preferences => Settings Default.
Then click on the Directories option, on the left.
You will see an option for Project Directory, click on the button to the right of the field. You will then need to direct this option to "\\Program Files\Predator Software\Common Files\Jobs".
Once this is done, click OK and you should be able to verify just fine. If this doesn't work, then you can try the reinstall, but I doubt you will have to.
Regards |
