Old 03-11-2009, 05:29 PM
cmnewcomer cmnewcomer is offline
cmnewcomer is on a distinguished road
ynnek,
I'm no expert but the Chain-Offset milling feature will offset the cutter from the drawn path by the amount set in Stepover Amount dialogue. This can be changed in the Setup option or the View Operation Properties window. When you select the object, it should show an arrow with a circle the size of the chosen tool. Make sure it is on the correct side of the line that you want to offset from!
I'm pretty sure that Path milling will not offset and simply follows the drawing path.
Best Regards.
Carl
