ok so do you have the software units step for metric? Or are you just typing in metric values?
Also for the post there is a variable to set metric for the code. But I would think you just downloaded the post off their website. So that should be setup right.
So yes it will work but something is wrong with your settings. Check the BobCAD program under preference setting part and default and make sure units is set to metric.
Also once you do this, Just re create the file. It's a simple part so it shouldn't take to long, and I think this will help.
Let me know |
