Originally Posted by dgalaxy it is definitly the nvidia card i did all the settings per bobcad but still does it
crashes about every30 seconds when i take the card out bobcad doesnt crash. all of my other programs work fine with the nvidia 8600gt except bobcad maybe somebody will jump on here and give me some help if i take the card out man alibre rhino corel they all look horrible i have to keep this card
John |
You may have to adjust the Nvidia Settings. For example the Triple Buffering works best turned OFF, while the Thread Optimization is set to AUTO, Maximum Pre-Rendered Frames set to 8, etc.
This is why I stepped away from common graphics cards and went to the CAD/CAM cards. There are fewer problems and better results.
One question, does your 8600gt have shared ram memory? You should really be using a card with Dedicated RAM.
If your card is using shared memory try increasing the virtual memory or buying more ram sticks. This might help with small files around 25mb but larger files around 35-100 will have white out screens and eventual crashes.
Good luck.
