Old 12-26-2004, 06:52 PM
ESjaavik ESjaavik is offline
*Registered*
ESjaavik is on a distinguished road
@Konrad: Thanks for the info. That takes care of the cleaning.
Can you please give some info on how to "dial up" the wheels?
One is made up of the diamond/binder ring on a wheel made of brass mounted on an arbor with a cone to match the grinder shaft and balancing weights. (Not CNC grinder.)
Another variety is on an aluminum wheel mounted on a common shop grinder. The PO used it for hand grinding. I will transfer it to a tool grinder mount of the same kind as above mentioned. If I can make it run without any runout I will only need to clean it as you wrote. Unless PO used it for too long with the runout of course.
One way I thought of is to mount it with the grinding surface onto the faceplate of the lathe and skim off the rear of the wheel. Will this work OK?
