Are they setting the feed and speeds on the tool page or the operations page ?
If they wish to take the feed and speed for the tool, then the tool muat be set-up correctly, and the "use tool's speed,feed,coolant" checkbox must be ticked.
This way, the operation will take the settings that you set for that tool at that moment, if you change any part of the tool parameters, you must reselect that tool again for it to update in other operations using the same tool.
You can modify parameters (speed, feed, etc ) in your operation after you select your tool,but if you reselect a tool, your modified parameters will be reset to the tool's parameters
Another good way of not getting F0. is to have an "Warning" error pop-up on the screen when posting that F0's exist, same goes for S0, or cutter comp take-up on arcs, that some machines don't like. |
