Old 12-26-2004, 02:15 PM
integral integral is offline
integral is on a distinguished road
15XT Spindle Driver Problems
Our 10hp 7500 rpm spindle on a 1996 Fadal 15XT(30x16 table) began to drop RPM's at various intervals. For example... while running 600 rpm, it would go from a load of approximately 30% up to approximately 90% and drop down to about 300-400 rpm. Seconds later it would recover and run fine for awhile. Service tech eliminated the possibilty of a bad encoder by swapping it for a new one, and the same problem persisted. This problem occurs at all speed ranges from low rpm up to 7500. Service tech suggested an all new Baldor Vector Drive. We had ours rebuilt, but now the spindle motor wants to spin backward, at 150% motor load, and only turning at 30 to 40 rpm in reverse with a S500M3 command. S500M4 command will make the motor want to try and spin clock-wise, but with the same 150% load. C axis fault Motor Overload occurs when I stop the motor from the STOP button on the Vector Drive. I do not know what the problem could be... bad Regen Resistor used for braking? Encoder now bad? I did run through the program function on the Vector Drive and zero balanced it to the machine. We even swapped out controller cards that went to software version FA7; the original card was software version FA5. If anyone has suggetions, please help!
