Originally Posted by keen Would the equidistant type toolpath starting from the centre cut 3D and finish with a cut arond the profile of the cavity edge?
Thanks in advance.. |
You have the option of starting the path on the inside and machining outwards or you can start on the outside and machine inwards...you can also set a rollover distand from part edge..If you use a boundry and your part is draw with outside profile surfaces it could also machine that in the same path...But doing an outside surface profile sometime it should be done as another operation
