Woa, I've seen the word Dampers thrown around before but it is the first time I've seen one in action. It looks like something I would be interested in putting on my machine once it is done.
Is the point of them to help the steppers to not loose steps by giving it a little torque support? If you have any additional infor and their prs and cons I'd really like to read about them.
Originally Posted by jalessi Dampers will help a lot if this is what you are experiencing. YouTube - 65 ipm
After adding dampers you might consider raising the power supply voltage to 36-40 volts, that will increase rpm about 30 percent.
Changing the screws to 2 start would double your feed rates.
Jeff... |
