Old 12-23-2004, 03:17 PM
Rekd's Avatar
Rekd Rekd is offline
Rekd is on a distinguished road
Almost forgot; formatting in the .pst file is important. In the example in my previous post, put the "if speed" lines AWAY from the left margin. If it's against the left margin, you'll get an undeclared variable error.
In the following code, I created 2 new functions that are triggered either automatically or by setting a switch in the Misc Value's Misc Integer section.
Note that the function name is all the way against the left margin, and the function itself is away from the margin.
Code:
popnumber	#Count Operations, add op type ()
	op_number = op_number + 1
	# = op_number
      n, "(", stopno, op_number, " ", stoper, ")", e
pcorner_round	#corner rounding ()
      if mi5 = 1 & mr5 > 0 & flg_mi5 = 0,
      	sav_mr5 = mr5,
      	pbld, n, "G187", *sav_mr5, e
      	flg_mi5 = 1
      if mi5 = 1 & mr5 = 0,
      	"( WARNING!! CORNER ROUNDING CONTROL HAS )", e
      	"( BEEN ENABLED WITHOUT A VALUE SET! USE )", e
      	"( MISC VALUES-MISC REALS TO SET A VALUE )", e
      	"( CORNER ROUNDING CONTROL IS DISABLED   )", e
      if mi5 = 0 & flg_mi5 = 1,
      	n, "G187", e
      	flg_mi5 = 0
Now, any time I want to call the pcorner_round function, I call it like this:
Code:
ptlchg0         #Call from NCI null tool change (tool number repeats)
      pcorner_round <----------call this function
      pcuttype<----------------then call this one
      toolcount = toolcount + 1<------do some stuff here
      if toolcountn <= tooltotal, nexttool = rbuf(4,toolcountn)<-----do some if then statements here
        else, nexttool = first_tool
      if mi10=one & op_id<>last_op_id, pstop <---- test an if then statement and call another function if true
Hope I'm not confusing you..
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
