Old 12-23-2004, 02:11 PM
Rekd's Avatar
Rekd Rekd is offline
Rekd is on a distinguished road
BTW, if you don't mind editing your posts, AFTER you back it up, you can modify this portion to tell you in the posted NC file WHERE in the post that particular line was generated..
Code:
# Debugging and Factory Set Program Switches
fastmode    : 1   #Posting speed optimizition
bug1        : 2     #0=No display, 1=Generic list box, 2=Editor
bug2        : 40     #Append postline labels, non-zero is column position?
bug3        : 0     #Append whatline no. to each NC line? 0
bug4        : 0     #Append NCI line no. to each NC line? 0
whatno      : yes   #Do not perform whatline branches? leave as yes
For example, when setting fastmode to 0, you'll get:
Code:
N2 M01                                  psof ptlchg_com
N3 ( OPERATION: 1   DRILL )             psof popnumber
N4 ( OP 3 90 )                          psof pcomment
N5 ( SPOT 6-32 )                        psof pcomment
N6 T2 M06                               psof p__8:1113
N7(T2: 1/4 CHAMFER MILL)                psof ptoolcomm
N8(MAX-DEPTH | Z-.07)                   psof ptlchg_com
N9(OP ID: 1)                            psof pstock
N10 M03 S7000                           psof ptlchg_com
N11 M00 (HIGH GEAR)                     psof ptlchg_com
N12 G00 G56 X-1.08 Y-1.2463             psof ptlchg_com
N13 G43 H2 Z1.                          psof ptlchg_com
/ N14 M08                               psof ptlchg_com
N15 Z.1                                 pzrapid prapidout
N16 G98 G82 X-1.08 Y-1.2463 Z-.07 R.1 P.3 F50.  pdrill
N17 X-.17 Y-.164 P.3                    pdrill_2
N18 G80                                 pcanceldc
N19 Z1.                                 pzrapid prapidout
N20 M09                                 ptlchg1002 pretract
N21 G90                                 ptlchg1002 pretract
N22 M01                                 ptlchg ptlchg_com
N23 ( OPERATION: 2   DRILL )            ptlchg popnumber
HTH
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
