The parallel port can be disabled in the bios. It could also be a faulty cable. As for the choppiness, maybe something to do with the microstepping? If your two setups are the same, you could always copy the *.ini file from the good one to the bad one. This would ensure all settings are the same. I thing I read it right that you have two pc's and two boards! |
