Old 12-22-2004, 11:06 PM
Rekd's Avatar
Rekd Rekd is offline
Rekd is on a distinguished road
You could set a switch to test for certain speed limits, and if it changes between the two, have it output the M00 codes.
Another way would be to use Misc Values, if you know what operations you'll be changing gears in.
You could also use Manual Entry toolpaths, with the 1005 setting to output code, then type in the code you want, (or select a text file that contains it).
Lot's of options. It depends on preference and necessity.
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
