I am running a American Rotary 5hp phase converter. I tried adjusting the spindle overload from the lowest to the highest setting but that didn't help. Originally I had a Bridegport tech wire the machine for 230 volts. Is there a way I can check an area with a voltmeter at startup to see if the voltage is dropping to low? I'm beginning to think a phase converter is not a reliable way to power this machine.
Thanks George. |
