Old 12-22-2004, 09:33 AM
cncwhiz cncwhiz is offline
cncwhiz is on a distinguished road
What if you tree pan or cut a groove a little bit bigger than the tube in the plate. Then slip the tubing into the groove and weld it? I would think that it would still warp but should be an even amount around the plate. When it is bolted to the floor it should pull the same. The other problem that I see is weather the surface you are sitting on is flat as well?
