I'd suggest rethinking the bearing/rail setup. As it is, you're putting all weight on the edge of the bearing. You'll most likely get a groove worn into the square tube rather quickly, as well as the bearings actually getting side to side forces from the angle pushing them apart, causing premature failure.
For these kinds of setups, most people are using bearings also set at 45deg so they sit flat on the tube. |
