Old 02-25-2009, 05:18 PM
chalky chalky is offline
chalky is on a distinguished road
I got the granite chips from a builders merchant in four sizes - dust, 6mm,12mm, and 14mm. I also used sand and glass bubbles. Dried the chips and sand in the oven at 160C for 45min. Then I mixed one 200ml plastic cup of each together in a plastic bucket. Pumped in four shots of resin and four shots of hardener and mixed everything together. Then I pumped in four more shots of resin and four of hardener followed by more mixing. You're supposed to mix the resin and hardener together first and then add the fillers. Done this way the resin/hardener mixture gets very hot very quickly ( the reaction is exothermic ) and will melt a plastic bucket if you don't get the filler in fast. Done my way the mixture only gets gently warm and you don't seem to get any bubbles either. This gave me a gloopy paste which I could spoon into the column of the mill. I tamped it down as best I could as I went along. The epoxy granite begins to set in about 15mins after mixing so you have to be fairly quick. You can get 106 hardener which will give you 30mins pot life but as I remember the epoxy doesn't then set quite as strong. In retrospect I could have made life easier by using one or two more shots of resin and hardener to make the mixture a little more runny. Left it overnight to cure and that was it. The mill column sounds really dead now when you tap it with a hammer. The epoxy granite fills all of the space and doesn't appear to leave any voids - at least it didn't when I test filled a small transparent plastic cup with epoxy granite. The resin and hardener I used were West System 105. I got it from a boat building supply supply house. I got the glass bubbles from them too. Its available in the US because Bob Warfield used the same stuff - see www.cnccookbook.com - thats where I got the idea from. A 1.2kg pack of resin and hardener cost about £20 ($30 ) and I've got loads left over, enough for my minilathe. I would advise you to buy the metering pumps for the resin and hardener because they automatically mix them in the correct ratio They cost around £10 ( $15 ) Hope this helps.
