Here is my prototype engine driven welder/air compressor/generator. The powerplant is a 13hp honda engine. The welding generator is a 150amp zena. Air compression comes via a york 210 refrige compressor, and should be good for 8cfm @ 90 psi. I will be adding a 5000kw 220v generator soon.
I figure I will have enough power to run 2 out of the 3 items at full power at a time. I will also be running a ready welder in the future (mig).
I'm probably going to make a run of 6 units in the spring, after I get all of the bugs out.
The last picture is the original welder. I mounted it on a 2x8. Don't laugh too hard, as I needed a welder to make a steel frame.
I've also uploaded the pics into the gallery.
DSL PWR |
