Old 12-19-2004, 05:43 PM
cadman's Avatar
cadman cadman is offline
cadman is on a distinguished road
Yes, pocketing and Material Only Machining. Turning geometry into AIR walls tells the system the tools can enter/exit through those places. It also allows the tools to overhang that geometry by whatever amount you enter in the OPEN SIDES dialog page. If you haven't been using this feature, once you use it you will wonder why you didn't. To use the Material Only Machining capabilities to it's fullest I would recommend going through the Mill Module Handbook.
Good Luck.
