Old 02-23-2009, 11:52 AM
stenly stenly is offline
stenly is on a distinguished road
Originally Posted by zafarsalam View Post
This message also appears if the lubricant reservoir at the back is empty. Check it out.
Zafar
Thanks Zafar.20 min before your post I found the problem- lubricant reservoir.
Another problem !!!
The tch145 does not control the spindel! Is it normal for this model Brigeport?
When i run the command the relay N16 moves on but the spindel is not running.And is it posible to change the spindel speed in program mode or just manually-ba pressing speeed button on the haed?
