Thread: Need Help! bottom of 3d pocket
Old 02-23-2009, 09:44 AM
Allen123's Avatar
Allen123 Allen123 is offline
Allen123 is on a distinguished road
The Z level finish is a water line tool path. It is used to clear the vertical areas not the flats.
You could do a planner tool path like burr said, or just do a 2D pocket to finish the flats.
Then run the Z level finish to finish the vertical walls.
This was just a simple pocket to clear stock and finish the flat
Now I did a Z level finish to finish the vertical walls.
