makes sure they show you it do something on your machine!
make sure they can output the code to disk in cni format! ( i have software for that)
is your running program limit 11k like most biesse old machines? if so useless for anything more than the simplest of jobs!
do you have the serial port connected on your machine?
alphacam is fantastic software, if your machine can run the code it generates- (your machine is probably limited to approx 350-400 lines of code max to run as 1 program)
id be interested to know what they say.
by the way alphacam works great for 2d panel work on biesse |
