Sounds as though your rotary axis transformation points are wrong.
What exactly are you calibrating and how are you doing it?
I would assume your calibrating the Rotary axis transformation points.
An easy way to check it is mount a block on the table, preferable off center, and define the X,Y,Z zero to one corner. Then Spatial Plane/cycle 19 rotate the C axis by 90 degrees and measure the same corner of the block should still be zero. Then try rotating the A axis and measuring the corner should still be zero if not you need to calibrate the Transformation points. |
