Old 02-22-2009, 01:24 PM
ihavenofish ihavenofish is offline
ihavenofish is on a distinguished road
Originally Posted by hoss2006 View Post
Welcome Gleas,
Check out SmithyCNC for one source.
The small 516 bed mill goes to 5000 rpm, the bigger mill 622 a little less at 3500 rpm.
The 622 could handle the 1 inch drilling.
Pretty much the same as the X4 from Syil America.
add novakon.net to the list. they sell similar machines to the smithy lines, but with slightly updated specs and slightly better pricing. 7000rpm for example on the nm070 (smithy 516 / sieg kx1).
at $5000 you could get the little mill and a bit of tooling. it will do 1x2 holes in aluminium using a 1/2" end mill and spiral pattern - wont do it efficiently with a 1" drill bit i dont think. youll need a coolant setup for this ideally too. my calculations say it would take roughly 3-6 minutes to mill such a hole based on the bit type, coolant, aluminium grade etc.
i have a sieg kx1 and its a pretty nice mill. surprisingly rigid and fast in aluminium and small enough to put anywhere. so if the limited travel (5"x10" ish) works for you, it might be a great choice.
