Old 12-17-2004, 05:21 PM
DAB_Design DAB_Design is offline
DAB_Design is on a distinguished road
Home limit switch wiring.
I picked up some switches today, and was reading through the Mach2 manual to figure out how to wire these.
Anyone care to check it over? My only questions (unless it is done wrong) is in the manual, it says to try and ground at the main control ground. Would it be ok to run the grounds to the capacitor, or should they go to the PC case that the controller is setup in?
Note: The image is not pretty, guess I'm showing my electronics ignorance again.
