You can wire them all to one pin, but then you must home each axis individually, as Mach3 will not know which switch is being triggered.
If they are wired individually, you can home all axis at the same time, and troubleshooting would probably be much easier.
__________________ Gerry
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
