Old 12-17-2004, 08:53 AM
ger21's Avatar
ger21 ger21 is online now
Originally Posted by Guy Smiley
Here's the dilemma. 1) In TurboCnc, the 15 inches of travel needed only the value 0.347 to cover the distance. Is this because I'm using a belt drive that translate 1:1? What do I need to configure to travel 1 inch when I type 1 inch? 2) In Master5, I encountered the pin configuration window and entered the Pins2-9 config and the AUX pin designations as specified by Xylotex. What do I input in the "Motor Configuration" values?
What version of TurboCNC. If version 4, under configure axis, in the scale box, the value is 1/ (steps per rev, usually 200, times microstepping, 8 if set at 1/8, times screw lead(turns per inch)).
If it's belt drive you need to use the distance traveled per motor revolution in stead of screw lead.
