Les,
The simplest way to clean up undercuts in my opinion is to run the simulation of the path you have already machined and the un-cut material will be obvious. Then use these areas to define your new machining regions.
There is probably some high end software out there that does this for you automatically, but I have not been exposed to it.
If you have only a four axis machine ( 3 + a rotary) some variation of this will be the solution whether it is automated or not.
The few high end packages I have been exposed to ran in the mid to upper teens ($ thousands)
I cut wood primarily and there is a real need to keep control of each specific cut for a multitude of reasons, so I haven't researched much more. ANY program that automates all the decision making is making a lot of assumptions in the process, no matter what you pay for it. The assumptions can be catastrophic in many cases, so I prefer a " manually" created path for each operation.
Best of luck, Phill
__________________ Phill Pittman
www.masterwerkes.com
phill@masterwerkes.com |
