Tolerance settings... | | Can I ask what others are using for the tolerance settings in MadCAM?
I've got the tolerance set to 0.005 mm in the Rhino options settings, and the cutter tolerance set to 0.01 mm in the 'select cutter' dialog, but although that makes the mesh very fine it's still clearly visible on curved surfaces after the finishing cut. The finish is very good, but I'm wondering if there's something I'm doing wrong that leaves the mesh visible. I can set the tolerance higher, but it's already taking a long time to calculate the toolpath (2.4 Ghz core 2 duo, 3 Gb ram, Vista OS).
Any suggestions?
Many thanks,
Jason |
