Old 02-18-2009, 11:07 PM
Geof Geof is online now
Originally Posted by MikeGT40 View Post
.....Most parts have a maximum diameter of 1.5". 60% are aluminum and 40% are titanium. Number of pieces will vary from 1 to 600. All holes on the perimeter are not off-set. Some parts do require machined flats. In most cases bar stock will not be used.
Thanks.
You need to budget at least $150,000 if you want a lathe with live tooling but for about half this amount you could get a Haas TL1-P and a Haas TM1-P and these would make your parts.
