Thread: Need Help! Biesse rover
Old 02-18-2009, 08:08 PM
knap knap is offline
knap is on a distinguished road
Hi Mario,
In the market the most accessible is AlphaCAM, and if you can find the old Biesse post then output of this you could directly key in to the machine controller. as for your info Biesse uses G codes but they also use fixed cycles (sub-routines) built by Biesse so instead of creating long lines to initiate a sequence it would instead be created in a single line, usually on the end of the line you would see L=???? (where ???? is the name of the fixed cycle)
cheers,
knap
