Can 4th axis do offaxis undercuts ? | | Do VM 4 axis toolpaths only cut with the tool axis pointing directly to the A axis , or can it cut 'off axis' to allow under cuts?
In other words, of the rotary table 4th axis holds a piece of bar stock, will the tool path always be restricted to pointing to the barstocks centerline?
Thanks,
-Les |
