Power Supply for Geckodrive | | I have a Nema 34 size of motor.It has a 6 amp per phase curent of consumption.White paper tells that a power supply must hase the 2/3 rated curent of motor i.e. 4 amp.But in microstepping mode is two windings of motor to connect to the power supply at the same time i.e. power supply must hase 12 amp of load current.What does power supply uses in may application in this case? |
