Old 02-18-2009, 09:06 AM
Captdave Captdave is offline
Captdave is on a distinguished road
File transfer 8025TG
I need a little help with setting up file transfer, this is the first time I have tried to use it. The software I'm using is Ezatrol, which is mainly used for Mazak controls but was told that it will work with other controls as well. I can send files to a device from the NC but can't receive them.
On OP mode 7, when I try to receive from a device it locks up an requires the control to be turned off then back on. It will do it even without the cable attached to the port. On a side note I can't get the DNC option to come on, not sure it needs to be on but I think that in the past it did come on but never tried to use it and can't be for sure.
