Thread: Need Help! Bridgeport R2E3
Old 02-17-2009, 10:44 PM
toadjammer toadjammer is offline
toadjammer is on a distinguished road
Bridgeport R2E3
I just purchased this machine and noticed a couple of possible problems that I want to make sure are right before I power it up. Attached is a picture and the two areas I question on this board is a pin socket that is void of a chipset and a jumper that was off of location. I circled both areas. This is the ECM3 Assy No 1937773 if that helps at all. Also does this type of machine have a cmos or other type of program that has to be put into the machine if the battery has run down? If so what is the process for doing this. And can I manually manipulate the drives and spindle controller to verify that they work before going through the work of loading the cmos? Thanks for your help, it has been a while since I messed around with CNC machines and want to get this up and running. I am aware that if this too far gone I will be looking at doing a retrofit but for right now funds are a little limited so that will have to wait.
Toad
