Also check all resets, circuit breakers and fuses in the cabinet. Also make sure you haven't hooked the wild leg of the converter into the control circuit. You should be able to move the axii off the limit switches by rotating the ball screws. I would doubt a 6t would alarm out if out of phase, but you might try that also. Also list your location, someone here with knowledge could have a look, maybe over a few beers and a pizza, as long as your buying! |
