Thread: motor direction
Old 12-14-2004, 06:39 AM
kong kong is offline
kong is on a distinguished road
Where do you set z=0? I use the top of the stock, and therefore all cuts will be in the negative direction, z home is set at the top of the z axis, but is only used as a means of getting the z out of the way, rather than a set datum point since I am using cheap micro switches. Hope this helps!
