Old 02-13-2009, 02:02 PM
hab82 hab82 is offline
hab82 is on a distinguished road
answer To My question
I finally found the answer to my question. This has been true for a couple of years and yet HF refuses to update its data. This is from a two year earlier thread. I don't really need it right now so I am going to wait until later and wait for new coupon.
Originally Posted by lewisd View Post
REAL dimensions on Harbor Freight 93885 Mill
I am a proud owner of the Harbor Freight Sieg X3 mill. [Harbor Freight #93885 . I brought it home from the freight dock today. Harbor Freight got Yellow Freight to send from Calif to Texas for $65.
Harbor Freight has created MAJOR CONFUSION in what you are buying.
Truth:
1.The Mill IS dimensioned exactly the same as the Grizzy sieg x3 item G0463.
2. The Harbor Freight online dimensions and advertising ARE TOTALLY WRONG. The Harbor Freight online Manual is TOTALLY WRONG. Discription is for the model manufactured by Sieg several years ago.
3. The Harbor Freight Manual packed with my mill is also WRONG and is identical to the one one their website which gives incorrect specs.
4. Download the manual and spec sheet for the Grizzly G0463 and that is what I bought from Harbor Freight (except in Red paint) I'm going to print the Grizzly manual so I will have an accurate manual!
5. The mill table IS 21 5/8 inches long like Grizzly mill instead of 17 5/8
as shown in Harbor Freight specs.
6. All critical dimensions for travel and ball screw length seem to be the same as the Grizzly mill.
I looked for hours on CNCZone for someone who had actually seen that the mills are actually the same and only found a post by Chris from Little Machine Shop. He had been in the Sieg factory in China and saw that the Grizzly and Harbor Freight were identical but for paint. That was good enough for me so I blindly ordered the mill knowing I might have to cut off my y & z ballscrew to make it fit if he was wrong. He was correct and I am very happy that my cncfusion kit will fit my mill without being cut down. I even have the terrible red waxey goo to remove so off I go to the auto supply to buy orange oil and wd40 to do cleanup.
Before buying online I checked with both local Harbor Freight Stores and they both said this mill is catalog only purchase.
