Old 02-13-2009, 11:19 AM
ihavenofish ihavenofish is online now
ihavenofish is on a distinguished road
Originally Posted by cowcowlee View Post
I'm sure the gib is well adjusted, also I read some elder post talked about this issue, the back side of the head stock near the vertical column just got about 0.01mm when I push it, however it comes 0.1mm near the spindle (caused by the lever effect), it makes the cutter brounce a lot even with the shallow cut. Just not sure it caused by the gap from dovetail or flex of the column, will take more measurement tomorrow.
Kral
that sounds alot like a loose gib. it could be flex, but its alot easier to rule everything "simple" out first.
