Old 02-12-2009, 06:50 PM
clembrant clembrant is offline
clembrant is on a distinguished road
I moved a DPM into my garage with 84" clearance height. I did take off the top cover. Also move head down as far as you can. I don't know if you know this but there are holes in the side base of the machine that are made to put round bars through so you can move the machine. This allows you to use a fork truck and get as close to the floor as you can. It's been awhile since I had mine moved( I did use a rigger),
so not sure if we had to tilt it, but I do remember it was pretty close, but I got it in. good luck
Name:	proto mill.jpg‎
ID:	75511   Click image for larger version
