Old 02-10-2009, 07:02 AM
moldmker moldmker is offline
moldmker is on a distinguished road
Originally Posted by BurrMan View Post
Doesnt V22 import solidworks files???.....
Yes, but if the model is complicated it takes a long time to load. Some I've aborted after 30 mins.
Convert it to .sat and it loads in 5 secs.
(my observation on my system, never confirmed on other systems)
Also, SW has different Configurations that can be applied to it's model. This is an engineering tool that allows a model to be configured in different states, such as: with or without holes (or just a certain hole), castings "as cast" and "as machined", sheetmetal parts "as bent" and "flat pattern", etc.
When you import a .sldprt into BC there's no opportunity to select which Configuration you want, so you get them all combined in one model.
Save it as a dumb solid (.sat, .igs, .stp) and it saves as the current config.
I got burnt once by a hole pattern mix-up, I don't chance it anymore.
If you're getting SW models from customers without prints, you may want to get SW's free viewer called eDrawings so you can verify model configurations.
moldmker
